Gonefshn11
Jun 30, 2024Initiate
Switch Management
Are there any POE+ or POE++ switches that can be managed with the Nighthawk app?
Netgear Cloud managed switches can be accessed by the Insight App, or by Web browser using the device local Web UI, or the Insight Web portal, and last but not least a basic SNMP.
As you posted in the Manged Switches community section: These are switches which are deployed in commercial AV infrastructures or business and enterprise deployments. Here the customers have local Web UI, classic Cisco-like CLI, complete SNMP, in specialized versions for IT and streamlined for AV, and for simplicity the local Netgear Engage Controller for Mac and Engage Controller for Windows available.
As the full name says, the Netgear Nighthawk WiFi Router App is dedicated to the named consumer routers, and to some extent also to the similar designated WiFi extenders.
- Gonefshn11InitiateThank you for your reply.
- BrianLNETGEAR Moderator
Hi Gonefshn11,
Welcome to the Community!
You can check the NETGEAR Smart Cloud Switches here, especially the ones that come with a 1-yr free Insight Subscription.
Kind regards,
BrianL
