Belpaire
Jun 14, 2019Follower
Trunk between Cisco and Netgear
Hello, At work we're working with cisco for Core and access layer (switches). Because we don't have enough outlets at certain points throughout the building we are forced to either make more or u...
devnull80s
Apr 06, 2024Aspirant
Hello,
After fiddling with this I got it going using Advanced VLAN 802.1q.
I think VLAN 1 has to exist but as I had been fiddling with this for hours I didn't want to risk removing it entirely.
Port 1 is my uplink.
Port 3, 4, 5 are links, each to different VLANs.
As using VLAN 1 is a no-no because it's usually the default everywhere I will give an example of mysetup using 11, 12, 13, and 14.
Cisco config real quickly:
usps#show run int gi 1/22
Building configuration...
Current configuration : 196 bytes
interface GigabitEthernet1/22
description wifi-uplink
switchport trunk encapsulation dot1q
switchport trunk native vlan 11
switchport trunk allowed vlan 11-14
switchport mode trunk
end
VLAN > 802.1q > Advanced > Port Configuration:
| VLAN ID | Port Members |
| 1 | 2 |
| 11 | 1 |
| 12 | 1 3 |
| 13 | 1 4 |
| 14 | 1 5 |
VLAN > 802.1q > Advanced > VLAN Membership:
VLAN ID 1: Port 2 (Untagged)
VLAN ID 11: Port 1 (Untagged)
VLAN ID 12: Port 1 (Tagged), Port 3 (Untagged)
VLAN ID 13: Port 1 (Tagged), Port 4 (Untagged)
VLAN ID 14: Port 1 (Tagged), Port 5 (Untagged)
VLAN > 802.1q > Advanced > Port PVID:
| Port | PVID |
| 1 | 11 |
| 2 | 1 |
| 3 | 12 |
| 4 | 13 |
| 5 | 14 |
Hope this helps anyone else going forward.
There is just one issue. The IP I gave it which is on VLAN 11 takes 6 to 7 times longer than the other VLANs. Ports 3, 4, 5 connect to devices. I'm using this like an edge switch. So I average about 0.25ms from my core switch to the devices on port 3, 4, and 5 respectively. But I'm at about 2ms from my core switch to the Netgear switch. It makes no sense, I probably have something messed up somewhere but not sure where.
Regardless as the edge devices have low latency and everything is just fine, no packet loss, loops or drops, I'm good as I got what I wanted. A Cisco trunk w/ 802.1q tagging and a native working.
schumaku
Apr 07, 2024Guru - Experienced User
Answered in the post here.
As you posted this now again in the Managed Switches community section, please note none of the Plus models you tagged [Gigabit Plus Switch Series (GS105Ev2), Gigabit Plus Switch Series (GS108E)] are in any aspect Managed Switches.
