shultzee13
Nov 01, 2024Aspirant
Turn off Multicasting per port on GS752TPP?
Can you turn off multicasting per port on this switch? If so, how? Thank you
shultzee13
Nov 02, 2024Aspirant
In layman’s terms - i simply need to know if i can disable individual ports on this switch ? I need to be able to disable multicast per port.
Thanks.
Thanks.
schumaku
Nov 03, 2024Guru - Experienced User
Convinced there is a control on the Web UI for administratively disabling select(ed) port(s), being for PoE, being for Ethernet ....
Granted, with the port disbled, there will be no more traffic on the port anymore.
Have asked before, or hopefully gave some ideas on your subject multicast question.
