Bolzenmann
Nov 10, 2023Aspirant
Unifi WLAN an Netgear und Unifi Switches VLAN Probleme
Hallo Community, folgendes Setup bereitet mir Kopfschmerzen: Es besteht ein gemischtes über Jahre gewachsenes Netzwerk aus [Anschluss > Edge Router > EdgeSwitches > Netgear GS728Tpp] An den Edge S...
schumaku
Nov 12, 2023Guru - Experienced User
All the ports configured to connect as an uplink to the customer existing network as well as where the APs are connected, must be configured as tagged for each VLAN, except of the UniFi admin network
Ensure no other VLANs are active on these ports except of the UniFi (and the NEtgear switch admin VLAN) admin network in untagged.
Just the presence of the SSIDs does not proof these SSIDs and brig the correct VLAN connectivity, any attempt to connect to these SSIDs will certainly nd with Zeroconf address on most clients, lack of a correct DHCP assignment on the client, wit wont help much usually.
Bolzenmann
Nov 12, 2023Aspirant
@shumaku
Thank you for your answer. But I tried that already, as this was the working configuration on the other switches.
I will spare you the screenshots of more Ts and Us.
But out of sheer desperation I went back to the basement and tried (not that i didn`t do that already last week):
On all VLANs but the default one, which i left untagged.
Trunk port tagged, uplink ports tagged
Trunk port tagged, uplink ports untagged
Trunk port untagged, uplink ports tagged
Trunk port untagged, uplink port utagged.
Nothing worked.
There has to be something else, that i am missing.
- BolzenmannNov 13, 2023Aspirant
All right,
the solutin was as easy as it was stupid (on my side).
It was a faulty cable.
Will check that first in the future.
