nasss
Mar 31, 2021Aspirant
Vendor specific packet drop
System Description............................. M4100-26G-POE ProSafe 24-port Gigabit L2+ Intelligent Edge PoE Managed Switch, 10.0.2.30, B1.0.1.1 Machine Model.................................. M41...
nasss
Apr 01, 2021Aspirant
Hi schumaku ,
Those messages are used by ATPD for HGW and Wifi bridge discovery.
Wireshark recognize the destination address as Dst: Spanning-tree-(for-bridges)_ef:03:fe. However it marks protocol type as Unknown (0xfe68) and not an STP
Topology:
WiFi Bridge <----->Switch<-----> HGW
schumaku
Apr 01, 2021Guru - Experienced User
If you don't need STP, you could try to disable it, and enable the "Forward BPDU while STP disabled", this exists AFAIK on the M4100 series, too.
I would expect they handle/filter the STP protocol based on src and dst address, not on the protocol number.
