User_JO
Nov 28, 2022Aspirant
VLAN Routing GS108Tv3
Hi,
in order to implement a VLAN in my private network, Netgear Support has advised me to buy a GS108 Tv3 Switch (in addition to existing GS308e and GS305e) because it allows "VLAN Routing" from the subordinated switches via a Fritzbox 7590.
However, in all online shops the following is offered:
Netgear GS108Tv3 Managed L2 Gigabit Ethernet (10/100/1000) Grau (GS108T-300PES)
- Netgear (GS108T-300PES)
- ArtNr: 6074892
- GTIN: 0606449138634
As you may see, the description shows in the header and the first bullet point in addition "GS108T-300PES" which implies that this may be different switch from GS108Tv3.
I am asking this because I had ordered a "GS108Tv3" in an online shop and was sent a "GS108T-300PES" instead (which I have returned).
Does this GS108T-300 PES allow VLAN Routing via Fritzbox (as GS108Tv3 as recommended by the support ??
Thanks your your help.
Alles klar, jetzt ist habe ich es verstanden. Danke für die Unterstützung, wahrscheinlich werde ich demnächst weitere Hilfe benötigen, sollte ich mein Wunsch-Scenario nicht hinbekommen.
Viele Grüße,
JO
Flats machen viel Freude und Freunde(-innen) !
Perfectly correct, even the description says "Netgear GS108Tv3 Managed L2 Gigabit Ethernet (10/100/1000) Grau (GS108T-300PES)". And no, this description was "enhanced" by one on-line shop/reseller only, these switches are offered and sold worldwide. The Ordering Information (SKU) does describe this switch, as offered in a box, with localized power supply, localized paperwork, localized glossy packaging.
https://www.netgear.com/de/business/wired/switches/smart-cloud/gs108tv3/
https://www.netgear.com/support/product/gs108Tv3.aspx
https://www.netgear.com/support/product/gs108Tv3.aspx#docs
The GS108Tv3, GS110TPv3 Data Sheet | 8-Port Gigabit Ethernet Smart Switches with Cloud Management does show all details:
GS108T-300NAS North America, Latin America
GS108T-300PES Europe
GS108T-300UKS United Kingdom
GS108T-300JPS Japan
GS108T-300AUS Asia Pacific
GS108T-300PRS ChinaThe comprehensive 8-Port Gigabit (PoE+) Ethernet Smart Managed Pro Switch with (2 SFP Ports and) Cloud Management Models GS108Tv3, GS110TPv3, and GS110TPP User Manual does show "Configure VLAN routing " starting from page 241.
- User_JOAspirant
Dear schumaku,
Thank you for your reply and the links.
Sorry for my English; if I understand you correctly, the "Netgear GS108Tv3 Managed L2 Gigabit Ethernet (10/100/1000) Grau (GS108T-300PES)" would fit my need for VLAN routing and the User Manual for GS108Tv3 (in your link) will apply for this switch (GS108T-300PES) ? So I can have at least a trial with that, and, if not, return it again.
Thank you for your help.
P.S.: The picture you are using, are these three dogs "Flats" (I also have one) ?
Grüezi User_JO - ja auch alles Flat Coated Retriever hier.
Mit dem GS108Tv3 kannst Du eine einfaches short-cut Routing zwischen mehreren VLAN bzw IP Subnetzwerken realisieren. eine kleine Anleitung dazu gibt es hier https://kb.netgear.com/24755/How-do-I-configure-VLAN-Routing-on-a-smart-switch
Deutsch geht hier immer - keine Angst vor der Sprchppolizei (welche auch ohne wirklichen Grund auch hier herumzieht....) als nur Mut mein neuer Freund: Diese Zeiten sind vorbei! Es gibt auch ein dedizierten Bereich https://community.netgear.com/t5/Deutsch/ct-p/German oder hier zu den Switchen https://community.netgear.com/t5/Switches/ct-p/de-business-switsches
