Newbie_x
Sep 23, 2020Aspirant
Which Netgear switch should I buy to get mDNS and IGMPv3 functionalities
Hi Netgear Community I have simple question. For newly installed solution we need to buy rack mounted switch with mDNS and IGMPv3 functionalities. 16 ethernet ports are enough but can be also bi...
- Sep 23, 2020
Hi Newbie_x
Thank you for your question and happy to help.
For full mDNS support (across VLANs, across switches, etc.) and full IGMPv3 (including our IGMP Plus automating it across switches), you should stay with either the new M4250 series or the M4300 series.
M4250 has a new 12x2.5G + 2x10G SFP+ model called M4250-12M2XF (MSM4214X-100EUS is the ordering SKU number in Europe) that you may consider.
M4300 has a perfect 24x1G + 2x10GBASE-T + 2x10G SFP+ model called M4300-28G (GSM4328S-100NES ordering SKU number in Europe) that you may consider too.
With either of these two models, mDNS Bonjour is guaranteed to work out of the box for seamless mDNS across VLANs, across switches, and with NDI audio-video etc. Same with IGMPv3, default VLAN 1 configuration is pre-configured with IGMP Plus, and you can replicate the VLAN 1 IGMP VLAN configuration (Snopping, Querier, etc.) on any other VLAN. This will work across switches (M4250/M4300 series) automatically as well.
Let us know of any other questions...
I hope this helps,
LaurentMa
Sep 23, 2020NETGEAR Expert
Hi Newbie_x
I hope this helps,
