Labdoc1
Jan 11, 2021Luminary
8-port 10G smart switch for ReadyNAS SMB network
Looking for help choosing a 10G switch: I have a new-to-me RN526x, which has 2x10G copper ethernet ports. Currently, it is connected to a Netgear GS108E switch (1 Gigabit x 8 ports). I would...
- Jan 12, 2021
Up front, 10 GbE is still a power hungry and hot technology.
The XS708E exsits in two versions.
The original XS708E was by far the first 10G switch for the SMB market with a very attractive price tag. Maximum power requirement was up to 220 W - and this heat has to go somewhere. It's EoL for a while already, the power requirement (and the heat dissipation was some 20.25% higher than the v2 model
The newer XS708Ev2 is rated lower:
Max power (worst case, all ports used, line-rate traffic) (Watts) 43.4W
Min power (link-down standby) (Watts) 13.7W
Heat Dissipation (max and min) (BTU/hr) Max: 148.39 BTU Min:: 46.85 BTUThe declared Acoustic noise level @ 25°C (dBA) (ANSI-S10.12) 36.7 dBA ...
All XSxxxE/EM models are offering basic configuration features, and very few monitoring capabilities.
The Amazon reviews are often held for years, and have typically no reference to the exact hardware version. On product lines where Netgear has released five or six vary different hardware versions, the obsolete reviews from years ago still beep up on top. rather confusing at least...
The XS708T came up around the same time as the 708Ev2, but offers some real managed switch core capabilities
Max power (worst case, all ports used, line-rate traffic) (Watts) 49.5W
Min power (link-down standby) (Watts) 26.3W
Heat Dissipation (Max and Min) (BTU/hr) Max: 169.00 Min: 89.79Acoustic noise level @ 25°C (dBA)(ANSI-S10.12) 27.4 dBA
Possible new members for such a set-up could be the newly introduced MS510TXM and MS510TXUP - two 1/10G SFP+, four MultiGig capable 10G copper, plus four 2.5G MultiGig ports. The PoE variant would allow to drive state of the art wireless access points (WiFi 6 2x2 and 4x4, like the standalone WAC214 and WAC218, or the cloud managed and 802.11k/v/r "Mesh" capable WAC5xx and WAX6xx), or to connect decent notebook(s) with 2.5G port.
Power Consumption
Max power (MS510TXM, worst case, all ports used, line-rate traffic) (Watts) 47.0 W
Max power (MS510TXUP, worst case, all ports used, full PoE, line-rate traffic) (Watts) 380.00 W
Min power (link-down standby) (Watts) 23.90 W resp. 31.50 W
Heat Dissipation (min w/o PoE and max with full PoE) (BTU/hr)
Max: 160.458 BTU/hr (MS510TXM)
Min: 81.5946 BTU/hr do.
Max: 1294.5888 BTU/hr (MS510TXUP)
Min: 107.541 BTU/hr do.Acoustic noise level @ 25° C (dBA) (ANSI-S10.12) 25 dBA (MS510TXM) resp. 33 dBA (MS510TXUP at max everything including max PoE++ - as it has three fans which are never always in sync, subharmonic waves will be audible)
Noise is always relative - even is on a low level, it can be intrusive.
schumaku
Jan 12, 2021Guru - Experienced User
Power Consumption
- Labdoc1Jan 12, 2021Luminary
Great reply! Thank you.
In the event, an XS728T showed up on eBay at an acceptable price. I went for it. Delivery in 10 days or so. Noise may be an issue -- I can place it in the basement away from offices/living area.
Thanks again for the detail
