PhilJW
Jun 14, 2021Aspirant
8 port version on GS724Tv3
Any help appreciated...... I have a home network with the GS724Tv3 24 port switch at its centre I now need to add and 8 port switch and as I'm not hugely knowledgable in these matters I'd rat...
DaneA
Jun 15, 2021NETGEAR Employee Retired
I suggest you the GS108Tv3 switch. Both of the GS724Tv3 and GS108Tv3 belong to the NETGEAR Smart Managed Pro Switch Models. Be informed that the GS724Tv3 switch is already End-of-Life (EoL).
Kindly check the specification of the GS108Tv3 switch on its data sheet here.
DaneA
NETGEAR Community Team
- PhilJWJun 15, 2021Aspirant
Many thanks - I spoke to Netgear who recommended the GS308T switch as I dont need PoE.
Id be interested to know if you agree? Or what the difference is?
- DaneAJun 15, 2021NETGEAR Employee Retired
The GS308T is also a good option. :)
Here is the difference between the GS108Tv3 and the GS308T switches:
1) The GS108Tv3 can be powered on using two methods. First is by using the power adapter that comes with its package contents. Secondly, by using Port 1 connected to a PSE (Power Sourcing Equipment) such as a PoE switch. Port 1 of the GS108Tv3 is a PoE PD (Powered Device) port that can receive PoE power so that you can you use the switch without a power adapter. As reference, kindly read pages 20, 23 and 38 of the GS108Tv3 Hardware Installation Guide here.
2) The GS308T can only be powered on using its power adapter that comes with its package contents.
DaneA
NETGAR Community Team
- PhilJWJun 16, 2021AspirantMany thanks
I don’t have a shortage of power sockets so I’ll go for the 308T
Cheers for your help
