Knowledge Base Article
New - RBE970 / RBE971 Firmware Version 9.13.2.1 Released
Release Date: NG Confirmed FW version.
October 31, 2025
Bug Fixes:
  • Resolved voice and video drop issues
  • Optimized the Clear Channel Assessment (CCA) threshold for the 2.4GHz band to improve wireless stability and reduce interference in congested environments.
  • Improved MLO roaming behavior to address connection issues when switching between router and satellites.
  • Fixed issue where sorting options were missing under Advanced → LAN → Address Reservation
  • Fixed authentication bypass vulnerability that allowed unauthorized password modification and admin access.
  • Fixed security issues
Download Link: Updated 11/2/2025
https://www.netgear.com/support/product/rbe972s
Firmware Update Instructions:
To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/RBE971.aspx#docs
IF MANUALLY UPDATING THE SYSTEM:
Be sure to update the RBS FIRST, then the RBR lastly.
Please navigate to the link below for step-by-step instructions on how to update your RBR971/RBS970:
Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities
I HIGHLY recommend after the FW is loaded on the system and it's back to ready, power OFF all Orbi units and the ISP modem/ONT for 1 minute. Then back ON with the ISP modem/ONT first, then RBR then RBS.
NOTE: Orbi app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too.
FW UPDATE ALL Feature:
If there is a FW updated seen on the RBRs web page and all RBS are online and connected with GOOD STATUS, you can select the UPDATE ALL button option to have the RBR update the RBS and RBR. Update All button is seen on the RBRs Firmware Update WEB page on the Check for Updates FW section of the page. Once FW has been checked for an update and all devices show the FW update is available, select the UPDATE ALL button. Give 5 minutes for the process to take place.
NOTE: If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. Use the ERASE button on the routers web page to factory reset the router:
Orbi Systems Manual Factory Reset Process | NETGEAR Communities
This sends a Factory Reset command to any and all connected RBS as well.
Quick Installation Guide, User Manual and Spec Sheet is here:
https://www.netgear.com/support/product/rbe971#docs
This article applies to:
Let us know how it works for you...Please make a new post regarding any problems your seeing in the Orbi BE support forums. Orbi WiFi 7 (BE) Mesh Systems | NETGEAR Communities
Thank you.
No CommentsBe the first to comment
