bwc_bl3h
Dec 21, 2020Initiate
ACL failing on Smart Managed Pro switch
Hello, I am trying to create an ACL that will allow HTTP access to a web server on TCP port 80 from anywhere and to TCP port 9999 from internal network only. The server is on switch port 8. I starte...
- Dec 23, 2020
I was adding the ACL to the port the www server was plugged into - this was the error. The rules only apply to INBOUND traffic - I applied the rule to the port that the cable modem is plugged into and it filtered exactly as expected for the www server.
bwc_bl3h
Dec 23, 2020Initiate
