dinnabeh
Apr 08, 2021Follower
ACL rules Netgear Switch
I have Netgear switch XS748T connected to SonicWall firewall.
Created 3 VLANs on the switch (VLAN20, VLAN40 and VLAN50) and the routing is done on the switch.
All VLans are getting the internet and all working fine.
I am trying to allow VLan20 to access VLan40 and VLan50.
Allow VLan40 to access VLan50.
Block VLan40 to access Vlan20.
Block VLan50 accessing VLan20 and VLan40.
I tried everything according to all documents available on the internet and never worked for me.
I created the ACL rules and applied them to the ports, and nothing worked.
SonicWALL - 192.168.100.1 – connected to port 1 on the switch
Switch – 192.168.100.5
VLAN40 – 192.168.40.0 – Ports 41 and 42 - untagged
VLAN50 – 192.168.50.0 – Ports 43 and 44 - untagged
VLAN20 – 192.168.20.0 – the rest of the ports - untagged
See attached images if it helps.
Thanks..
I followed all of the following documents as a guide:
https://drive.google.com/file/d/157I76Cj18C2t3QgM5fRSPNTZuxVvec11/view
https://drive.google.com/file/d/0B4PuVEYxkQ5oX0w0Yll0U1d2MlE/view
Unfortunatly, none worked.
1 Reply
- DaneANETGEAR Employee Retired
