ITLorenzoC's avatar
ITLorenzoC
Switch Netgear GS324T
Buongiorno, elenco alcune domande/dubbi per lo switch in oggetto:
- come abilito il protocollo Telnet? per ora riesco ad accedere allo switch solo tramite un pc collegato alla stessa lan
Se poi me ne vengono in mente altre/i, mi farò vivo 😄
Grazie.
Saluti
    • ITLorenzoC's avatar
      ITLorenzoC
      Thank you for your prompt and comprehensive response. Can you confirm that this switch is only accessible via browser from a device within the same LAN? Thanks for the support.
      • schumaku's avatar
        schumaku
        IPv4 routing and subnet permitting - unless I'm wrong -  any routeable source IP can reach these devices, even beyond the local IP subnet.
ProSupport for Business
