ITLorenzoC
May 05, 2023Aspirant
Switch Netgear GS324T
Buongiorno, elenco alcune domande/dubbi per lo switch in oggetto: - come abilito il protocollo Telnet? per ora riesco ad accedere allo switch solo tramite un pc collegato alla stessa lan Se poi...
- May 05, 2023
To my knowledge, the NETGEAR Smart Switch's lite CLI is not available on the GS324T.
FMI https://kb.netgear.com/000064429/mDGAprccBFuwkbucoaaNIopZdHGsufWx?article=000064429
Matter of fact, the IPv4 stack and the IPv4 stack is the same for all protocols including telnet - the limitations in IPv4 routing are the same for obvious reasons.
Said that, the Web UI remains reachable over any kind of VPNs for example.
ITLorenzoC
Thank you for your prompt and comprehensive response. Can you confirm that this switch is only accessible via browser from a device within the same LAN? Thanks for the support.
schumaku
May 05, 2023Guru - Experienced User
IPv4 routing and subnet permitting - unless I'm wrong - any routeable source IP can reach these devices, even beyond the local IP subnet.
