ITLorenzoC
May 05, 2023Aspirant
Switch Netgear GS324T
Buongiorno, elenco alcune domande/dubbi per lo switch in oggetto: - come abilito il protocollo Telnet? per ora riesco ad accedere allo switch solo tramite un pc collegato alla stessa lan Se poi...
- May 05, 2023
To my knowledge, the NETGEAR Smart Switch's lite CLI is not available on the GS324T.
FMI https://kb.netgear.com/000064429/mDGAprccBFuwkbucoaaNIopZdHGsufWx?article=000064429
Matter of fact, the IPv4 stack and the IPv4 stack is the same for all protocols including telnet - the limitations in IPv4 routing are the same for obvious reasons.
Said that, the Web UI remains reachable over any kind of VPNs for example.
schumaku
May 05, 2023Guru - Experienced User
- ITLorenzoCMay 05, 2023Aspirant
Thank you for your prompt and comprehensive response. Can you confirm that this switch is only accessible via browser from a device within the same LAN? Thanks for the support.
- schumakuMay 05, 2023Guru - Experienced User
IPv4 routing and subnet permitting - unless I'm wrong - any routeable source IP can reach these devices, even beyond the local IP subnet.
