reelyator
Aug 30, 2020Aspirant
Admin Page of GS108Ev3 not acessible
Hi Guys, since years i am using 2 GS108Ev3 Switches in my homenetwork without any problems. The first directly connected to my Fritzbox. The second is in my livingroom with my whole homecinema equ...
- Sep 05, 2020
Summary: After setting the speed on all Ports back to AUTO and rebooting both switches everything is back to normal again. File transfer speed around 100 MB/s
schumaku
Aug 30, 2020Guru - Experienced User
reelyator wrote:No problem with the livingroom switch. it was found on the NETGEAR SWITCH DISCOVERY TOOL, Admin Page was acessible, i upgraded the FW and switched the speed of all ports to 100M full. After that Transfer speed was still too low (around 1 MB/s).
Only Fast Ethernet devices connected or wiring not allowing Gigabit Ethernet (e.g. to the other switch)? Something fishy...
reelyator wrote:Then i tried it through the Prosafe Plus Utility. The swith is found, when i select it i get asked for the password, but after entering the PW i get the error message that the swith and the manager IP are not in the same subnet. This is stange because the PC the manger is running on is DIRECTLY connected to the fritzboix switch through LAN....
Nothing strange - TCP/IP does require two systems on the same LAN to be in the very same IP subnet. It does not matter where the switch is connected to. To access the switch (assuming on it's default 192.168.0.239/24 network) you could either enable the router DHCP server and reboot that switch so it does pick-up an address from your subnet, or configure any system on the network to an address in the 192.168.0.x/24 (255.255.255.0) subnet.
reelyator
Sep 05, 2020Aspirant
- reelyatorSep 05, 2020Aspirant
btw: Thank you for your feedback!!
- schumakuSep 06, 2020Guru - Experienced User
reelyator wrote:After setting the speed on all Ports back to AUTO and rebooting both switches everything is back to normal again.
IEEE standards is mandating auto-negotiation on Gigabit and faster Ethernet ports. Therefore, the port settings allow 10Mb/s and 100Mb/s speeds only. For Gigabit, stick with AUTO.
reelyator wrote:File transfer speed around 100 MB/s
The original post was a little bit confusing on this point - be careful with the units MB/s (== MBytes/s) vs. Mb/s (== Mbit/s)
Glad to help!
- Apr 13, 2023Anonymous
