Rodrigoc's avatar
Rodrigoc
Can't acess mywifiext
Good morning,<br><br>I am not able to acess the extender configuration local website by any means. Need help to rw configurate my extender after a eletric power shortage when it lost its configuration.<br>I am able to visualize its network but I can't acess the website to conclude its setup. Even using its IP address.<br><br>Thanks.
  • Did you set it up using the push button WPS option?
    If so, factory reset the extender  and set it up using the installation assistant.
    To factory reset, push and hold the reset button for 7-15 seconds while powered on.
    Here's a video of how to use the assistant.
    https://www.youtube.com/watch?v=yJVklshxBMk
  • plemans's avatar
