ChoppaOnThaCouc
Jul 09, 2021Aspirant
After static IP, and VLAN, how do I connect to my GS308E?
So I just recently purchased the GS308E 8 Port Enhanced Switch. I set up the VLAN on ports 1 and 2 for my gaming devices but afterwards I set up static IP for my router and unfortuanly now my route...
schumaku
Jul 10, 2021Guru - Experienced User
While it's a little bit unclear on how this additional VLAN does fit to the unknown router and IP subnet et all - most Plus swiches are discoverable (as the management isn't restricted to a management VLAN, and if configured to DHCP it can pick an address from any VLAN) by the NETGEAR Switch Discovery Tool (NSDT).
- ChoppaOnThaCoucJul 10, 2021Aspirant
i fixed it had to re-do everything thanks
