aSpartan111
Oct 11, 2023Tutor
GS308E Power issue
Hello,
I'm contacting you regarding an issue i have with one GS308E.
After coming back from vacation (powered off for 2 weeks), it doesn't turn on anymore.
The Power and the right led on port 8 blinks at 2Hz average.
I tried with another PSU from another GS308E and the issue remains.
The PSU from the dead GS308E works on the other switch.
I also tried a factory reset without any impact.
I tried asking for material assistance on my support page (669 days remaining).
But every-time i try submitting my message i get the "something went wrong" error.
What are my options now regarding the warranty ?
Should I RMA it ?
Thank you in advance for your answer,
cordially,
Benjamin
Here is a video turned into GIF of the issue :
Benjamin
Wrong entry points posted before...
Much easier to head to https://my.netgear.com/ ... assuming you have registered your switch, it will show in the list of Registered Products. Click on it, and follow the [Request Hardware Support] process. Add a link to your post in the community as a description. No need to open a pure support ticket 8-)
If it's under warranty, you should get it RMAd.
You'll need to contact NG support for this:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspxHello,
Thank you for your answer.
I wish this was that easy.
I get conflicting data regarding the issue and no obvious way to submit a RMA request.
I get the following possibilities/answers when I : -> clic on your links -> Acces to support -> Open a support file -> then I select the right SN :Your free technical support expired on 2020-11-09.
Your product is covered by hardware warranty until 2025-08-10.
Your product is no longer covered by warranty and no contract is available for purchase.
Suggested answers from our knowledge base
--Several lines to KBI can't find an answer to my problem, I would like to contact NETGEAR support. Depending on your serial number and date of purchase, NETGEAR may offer the following support solutions:
Search the knowledge base
Visit the communitySo i am covered by hardware warranty until 2025-08-10 but i get no easy way to submit an RMA request.
Am i doing something wrong ?
Cordially,
Benjamin- schumakuGuru - Experienced User
