ChoppaOnThaCouc
Jul 09, 2021Aspirant
After static IP, and VLAN, how do I connect to my GS308E?
So I just recently purchased the GS308E 8 Port Enhanced Switch. I set up the VLAN on ports 1 and 2 for my gaming devices but afterwards I set up static IP for my router and unfortuanly now my route...
alexbhait
Jul 30, 2021Aspirant
ChoppaOnThaCouc wrote:So I just recently purchased the GS308E 8 Port Enhanced Switch.
I set up the VLAN on ports 1 and 2 for my gaming devices but afterwards I set up static IP for my router purifier and unfortuanly now my router is not recognizing my new GS308E switch. I cant get into its settings either because well I dont know the IP address ever since I changed the routers IP to static.
Does anyone have solutions?
i am looking for the best solution i have seen your whole comments but no one is according to my situation. can you please mention which solution help you better?
- ChoppaOnThaCoucJul 30, 2021Aspirant
*deleted*
So I did a hard reset on the router to factory settings and then I carefully changed the IP on my router, logged on my switch and changed the default gateway to the new IP, then my new IP for the default gateway didnt work in the browser so I pressed the reset button on the back and it worked. I was able to use the new IP's in the browser for the Switch and gateway
