tessus
Jul 09, 2022Guide
after upgrading GS324T to 1.0.0.41 I can't login anymore
I upgraded the firmware of my GS324T to 1.0.0.41 (from the previous 1.0.0.38), but now I can't login anymore. I always get the message Login failure. The strange thing is that the switch seems t...
schumaku
Jul 09, 2022Guru - Experienced User
tessus wrote:
Thus I thought maybe the firmware upgrade reset the password (since the upgrade fixes a few security vulnerabilities), but I tried all of Netgear's standard passwords, but to no avail.
Nothing the like. Since some much earlier firmware releases from about 2019 there was just changing the default password was enforced. However, you had ben able to login before for the update.
Tried to use the [log in] button instead pf pressing the <enter> key?
tessus
Jul 09, 2022Guide
Thanks for your reply. Yes, I tried the login button, but I did not try the enter key.
I am currently locked out and I have to wait 5 minutes.... I'll let you know then.
