tessus
Jul 09, 2022Guide
after upgrading GS324T to 1.0.0.41 I can't login anymore
I upgraded the firmware of my GS324T to 1.0.0.41 (from the previous 1.0.0.38), but now I can't login anymore. I always get the message Login failure. The strange thing is that the switch seems t...
tessus
Jul 09, 2022Guide
Nope, the <enter> key does not work either. I am really puzzled by this. Never had any issues like this one.
schumaku
Jul 09, 2022Guru - Experienced User
Thank you for trying. The issue I had in mind was more the other way round.
Dropping the browser cache might help, too.
What browser make and version, what base OS?
- tessusJul 09, 2022Guide
I tried Firefox and Safari. I also cleared the cache. It did not help. I'm using macOS 10.14.6, but I am not sure what the OS has to do with it. I could log in 2 hours ago (before the upgrade).
I don't want to be ungrateful, but the upgrade messed something up. It either changed the password to an arbitrary value or maybe restricted the access to a specific IP address. But I am not using the default network that Netgear uses upon factory reset, so that's that.
I am not sure, whether Netgear devs are reading this, but they should have done better QA. The update locked me out of my switch. At least I can still use my network, but I do need access to my switch....
Is there a way to tell the switch to boot into the other image? If this is not possible without logging in, this dual image feature is pretty much useless.....
