tessus
Jul 09, 2022Guide
after upgrading GS324T to 1.0.0.41 I can't login anymore
I upgraded the firmware of my GS324T to 1.0.0.41 (from the previous 1.0.0.38), but now I can't login anymore. I always get the message Login failure. The strange thing is that the switch seems t...
tessus
Jul 12, 2022Guide
Thanks, I will try this in the evening. I am working from home and I can't disconnect the switch from the network at the moment.
How am I supposed to do that anyway? Unplug all the cables? In that case I will have to label all cables and tape them to the desk.... This can take a while.
schumaku
Jul 12, 2022Guru - Experienced User
Disconnect only the uplink, and probably the devices which might go wrong if associating with a wrong VLAN should be sufficient.
