Datoeter
Feb 25, 2020Aspirant
Orbi satellites do not connect anymore
Hi All,
Till yesterday my Orbi's worked fine, i have two indoor satellites and one outdoor satellite. Now i seems that the router cannot connect with the satellites. I tried rebooting, manual syncing etc. When i login into the router i see on the home page under satellite 2 (the outdoor is not connected right now). But in my app i can't find them. the network map shows for all satellites maganta.
Do anyone have any sugestons?
The firmware is:2.3.5.30 for the indoor.
For the outdoor it is: 2.3.5.32.
I tried updating new firmeware, there seems to be no new firmware.
Hi all,
I returnened the Orbi set and got a new set. The old set was faulty. I connected the new set, there were no problems.
Thank you all for your help.
- Retired_Member
You may want to look again at your FW source. Most FW chasers report that the number on the FW is the same for both the Orbi router and Sat.
Try a factory reset on the RBR and ALL RBS. Bring the RBS near the RBR and try to add them, 1 at a time. 6-10feet.
Let us know if this works, if so, then place the RBS back in there remote locations.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).- Retired_Member
FURRYe38 wrote:Try a factory reset on the RBR and ALL RBS. Bring the RBS near the RBR and try to add them, 1 at a time. 6-10feet.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).any comment on the FW numbers??
RBSY FW version will differ from RBR/RBS. Depending upon the mode. Most recent version doesn't match up with RBR/RBS. Doesn't seem to keep in line with RBR/RBS versions. Just as long as the RBSY is using the latest version available.
RBR/RBS has v2.5.1.8 for manual update if they choose to manually update here.
