bigc1955
Sep 01, 2018Aspirant
Allow device between two VLANs - JGS524Ev2
Good morning. I have a VLAN set up on my switch. Is there a way to have devices on one VLAN see one (yes, just one) device on the other VLAN? For example, if I have music stored on a server and wa...
- Sep 03, 2018
Hi bigc1955,
Welcome to our community! :)
That would be possible if you are using a Smart Switch as it can handle VLAN routing per interface. Unfortunately, JGS524Ev2 does not support VLAN routing. But if your router is capable of inter-VLAN routing, then we can communicate this 2 VLANs.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
