BoboBear
Dec 08, 2016Aspirant
Apple Airport Extreme VLAN
I'm trying to setup a guest network on my Airport Extreme. Apple automatically makes this VLAN with ID 1003. The Airport Extreme is plugged into port 2 of my Netgear Swtich. Port 1 plugs into the...
- Dec 08, 2016
Hi BoboBear,
Welcome to Netgear community
Are you connecting you device as this?
If right ,I think at least we need to add port 1 to vlan 1003 too.
Just config port 1 as you do for port 2 .
Regards
Carl
Netgear Employee
Carl_z
Dec 08, 2016NETGEAR Expert
Hi BoboBear,
Regards
Carl
Netgear Employee
- BoboBearDec 09, 2016Aspirant
Thank you. It works. I somehow thought port 1 was a trunk port by default and that's why my router was plugged into port 1 of the switch.
I'm going to spend some time poking around the Netgear KB today.
