BoboBear's avatar
BoboBear
Apple Airport Extreme VLAN
I'm trying to setup a guest network on my Airport Extreme. Apple automatically makes this VLAN with ID 1003.   The Airport Extreme is plugged into port 2 of my Netgear Swtich. Port 1 plugs into the...
  • Carl_z's avatar
    Dec 08, 2016
    Hi BoboBear,
    Welcome to Netgear community
    Are you connecting you device as this?
    If right ,I think at least we need to add port 1 to vlan 1003 too.
    Just config port 1 as you do for port 2 .
    Regards
    Carl
    Netgear Employee
ProSupport for Business
