peos42
Mar 12, 2018Tutor
Auto-DoS
Hi Is the Auto-DoS function a joke???? If this is enabled it is enough for an attacker do just send one malformed packet and the Negear according to the docs shuts down the port permanently u...
- Mar 19, 2018
I understand how it works now. Not ideal for us. But you sorted it out for me. For that I thank you very much.
/Peo
JohnC_V
Mar 19, 2018NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if everything is ok now or you still need further assistance.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
peos42
Mar 19, 2018Tutor
/Peo
