sbankscharlie
Aug 19, 2021Aspirant
Auto-Video Vlan Setup
Currently I have a seperate network just for my video cameras so everything is on VLAN1. I have four Axis Cameras along with two other switches and miscellanous equipment including my NVR. I have w...
schumaku
Aug 22, 2021Guru - Experienced User
There is not much rocket science in these Auto-VLAN configs.
If you are connecting multiple devices to a port (like a computer and a VoIP phone, or even more devices on a small edge switch like a computer, an VoIP phone, a security camera) you can run the computer on the primary VLAN (port untagged, PIVD same), while the VoIP phone and the camera can be associated - based on the OID-part of the MAC address - can be automatically associated with the VoIP resp. the video VLAN.
If done normally, you would either have to configure access ports for each VLAN on the edge switch associated untagged to the computer, one access port untagged for the VoIP VLAN for the VoIP phone, and one access port untagged for the video VLAN for the camera and have a trunked uplink with all or all minus one VLAN tagged. Or if using a simple unmanaged edge switch, you would have to configure the VoIP phone interface tagged for the voice VLAN (this is commonly easy possible), the camera interface tagged for the video VLAN (not a typical feature on cameras), ...
sbankscharlie
Aug 22, 2021Aspirant
If I thought Auto VLANS were rocket science then I would not be confused. It is the "Auto" part that I don't get, the rest of what you said I know.
When I had phones, they never auto configured for Auto-VoIP. I had to create my own VLAN and configure the switch manually.
NOW I have cameras and a switch with Auto-Video. I have enabled Auto-Video but the cameras remain on VLAN 1.
The reason for my post is I understand and can work with vlans manually but twice now the Auto vlan feature isn't do what I understood it should be doing. Shouldn't my cameras automatically show they are on the video vlan?
Thanks
- schumakuAug 22, 2021Guru - Experienced User
Have the camera OIDs configured for the (Auto-)Video VLAN?
- sbankscharlieAug 22, 2021Aspirant
If I understand your last question, no the cameras OIDs have not configured for the (Auto)-Video. There is no indication that the switch is aware that the cameras are any different then the other devices connect to the switch.
- schumakuAug 23, 2021Guru - Experienced User
Well, the OIDs (the first half of the device eg. the camera MAC address(es)) must be configured on the switch to make the the Auto-"any" aware that a certain MAC should be associated with the Auto-VLAN of course. As I said: There is no rocket science magically "detecting" what could be a camera, or a VoIP phone, ...
However, I must admit reviewing the S350 Series 24-Port (PoE+) and 48-Port Gigabit Ethernet Smart Managed Pro Switches with 2 or 4 SFP Ports User Manual does not show an OID config requirement for the Auto-Video VLAN (very different from many other current Netgear switch models). Much more it does talk of "Auto-Video Multicast" settings only. At this point I'm more than confused on how this feature should work here in reality - considering a camera does initially connect to the data VLAN and get it's IP address there on detecting an IGMP Multicast registration probably?
Don't these switches have an OUI table config on Switching -> Auto-Video -> OUI-Based -> OUI Table similar to Auto-VoIP?
