M4sis
Jul 12, 2017Aspirant
IGMP Auto-Video
Hello,
I seem to be having a problem with the IGMP Snooping page on the XS728T.
I disable auto-video for all my VLANs and then proceed to add the VLANs for IGMP snooping but once the snooping VLANs have been added the auto-video enables itself for each VLAN.
If I then disable auto-video again my previous snooping VLAN config gets cleared?
I'm getting the same on 2 separate XS728T switches and have tried all 3 firmwares for the switch with the same happening.
I manage a network with other netgear switch models including the XS716T and they all allow the auto-video to be disabled whilst having snooping VLANs setup.
Anyone else getting this issue?
Thanks,
Mark.
Hi M4sis,
Yes, change IGMP Snooping Querier configuration will affect for Auto-video configuration. Due to the Auto-video feature simplifies IGMP Snooping querier configuration… from the Auto-video Help. They will keep accordance.
NETGEAR Employee
- ElainePNETGEAR Expert
Hi M4sis,
Welcome to NETGEAR community!
I try to do on XS728T, after creating new vlan 10, all vlans are Disable for Auto-video. Then enable IGMP Snooping on global, and add IGMP Snooping vlan10 by created before. However, the vlan 10 is still Disable for Auto-video as default.
Please confirm that: once the IGMP snooping VLANs have been added , the auto-video enables for each VLAN?
NETGEAR Employee
- M4sisAspirant
Hi ElaineP,
Yes that's correct, after enabling IGMP Snooping on global and adding snooping VLANs the auto-video becomes enabled for the snooping VLANs that have been added.
If I add VLAN 10 to the snooping VLAN, VLAN 10 becomes enabled in auto-video.
If I add VLAN 20 to the snooping VLAN, VLAN 20 becomes enabled in the auto-video.
If I then disable auto-video for VLAN 10 & 20 the snooping VLANs get cleared.
