M4sis
Jul 12, 2017Aspirant
IGMP Auto-Video
Hello, I seem to be having a problem with the IGMP Snooping page on the XS728T. I disable auto-video for all my VLANs and then proceed to add the VLANs for IGMP snooping but once the snooping VL...
ElaineP
Jul 12, 2017NETGEAR Expert
Hi M4sis,
Welcome to NETGEAR community!
I try to do on XS728T, after creating new vlan 10, all vlans are Disable for Auto-video. Then enable IGMP Snooping on global, and add IGMP Snooping vlan10 by created before. However, the vlan 10 is still Disable for Auto-video as default.
Please confirm that: once the IGMP snooping VLANs have been added , the auto-video enables for each VLAN?
NETGEAR Employee
- M4sisJul 12, 2017Aspirant
Hi ElaineP,
Yes that's correct, after enabling IGMP Snooping on global and adding snooping VLANs the auto-video becomes enabled for the snooping VLANs that have been added.
If I add VLAN 10 to the snooping VLAN, VLAN 10 becomes enabled in auto-video.
If I add VLAN 20 to the snooping VLAN, VLAN 20 becomes enabled in the auto-video.
If I then disable auto-video for VLAN 10 & 20 the snooping VLANs get cleared.
- ElainePJul 13, 2017NETGEAR Expert
Hi M4sis,
The vlan 10 is still Disable for Auto-video as default.
Please offer more description or you do follow my steps and the result is different my? If it's convenient, please share me one video to analyze. Thanks very much!
NETGEAR Employee
- M4sisJul 13, 2017Aspirant
Hi ElaineP,
I've just discovered that it seems to be linked to the IGMP Snooping Querier. I have Querier Admin Mode enabled but if I disable this the auto-video disables too.
