M4sis
Jul 12, 2017Aspirant
IGMP Auto-Video
Hello, I seem to be having a problem with the IGMP Snooping page on the XS728T. I disable auto-video for all my VLANs and then proceed to add the VLANs for IGMP snooping but once the snooping VL...
M4sis
Hi ElaineP,
Yes that's correct, after enabling IGMP Snooping on global and adding snooping VLANs the auto-video becomes enabled for the snooping VLANs that have been added.
If I add VLAN 10 to the snooping VLAN, VLAN 10 becomes enabled in auto-video.
If I add VLAN 20 to the snooping VLAN, VLAN 20 becomes enabled in the auto-video.
If I then disable auto-video for VLAN 10 & 20 the snooping VLANs get cleared.
ElaineP
Jul 13, 2017NETGEAR Expert
Hi M4sis,
The vlan 10 is still Disable for Auto-video as default.
Please offer more description or you do follow my steps and the result is different my? If it's convenient, please share me one video to analyze. Thanks very much!
NETGEAR Employee
- M4sisJul 13, 2017Aspirant
Hi ElaineP,
I've just discovered that it seems to be linked to the IGMP Snooping Querier. I have Querier Admin Mode enabled but if I disable this the auto-video disables too.
- ElainePJul 13, 2017NETGEAR Expert
Hi M4sis,
Yes, change IGMP Snooping Querier configuration will affect for Auto-video configuration. Due to the Auto-video feature simplifies IGMP Snooping querier configuration… from the Auto-video Help. They will keep accordance.
NETGEAR Employee
Hi ElaineP,
Okay, so the auto-video feature won't move the multicast traffic to a different VLAN like the auto-voice does?
Sorry, this is the first time I'm seeing this presented in this way, other netgear switches I've used like the XS716T have the auto-video VLAN prefixed so it's just confused me a bit.
