hosregla
Aug 25, 2015Aspirant
best option, 2 netgear Prosafe GS724T-400EUS in trunking or 1 gs748teu,
best option, 2 netgear Prosafe GS724T-400EUS in trunking or 1 gs748teu, do you have the same performance both options. 2 netgear prosafe 24 are best price. 2 Netgear ProSafe GS724T-400EUS - Sw...
- Aug 25, 2015
Hi hosregla,
Welcome to the community!
I would go with the single GS748T, it's much easier to manage if you only have one unit. In terms of performance, this should be the same, using 2 switches with trunk ports benefits works better if you have multi-sessions on both switches. If your network activity uses single session, it will max out the first port's bandwidth before using the second one. I am hoping some other users here can give more input.
If you have more questions, feel free to ask.
Thanks,
JohnRo
Aug 25, 2015NETGEAR Employee Retired
Hi hosregla,
Thanks,
- hosreglaAug 26, 2015Aspirant
GS724Tv3,GS724Tv3,GS748Tv4H1,GS748Tv4H2
have 5 units, should create trunking between them. each unit is separated by 40-60 m
is it necessary create vlan to make trunking???
thks.
Alfonso Silván.
- JohnRoAug 26, 2015NETGEAR Employee Retired
Hi hosregla,
I have to be clear on what you are trying to accomplish, do you just want the devices to be connected on a single network? If you have a diagram of your network plan, that will help us in giving you the correct suggestions.
I'll look forward to your response.
Thanks,
- hosreglaSep 01, 2015Aspirant
thks by your time.
i have five server . AD (w2003), PACS SERVER KODAK (w2008), ESXI 5.5 , 1 BBDD MYSQL W2008, 1 BBDD SQL SERVER 2008)
50-55 pc clients win 7, and 5 or 6 machine medical.
router 192.168.0.249 --> ddwrt 100 mbit
router 192.168.1.100 --> (ONO ISP SPAIN) HITRON CDE-30364
submask in AD & computer & servers 255.255.255.0
192.168.0.132 ->GS748Tv4H2
192.168.0.133 -->GS748Tv4H1
192.168.0.138 --> GS724Tv3
192.168.0.139 --> GS724Tv3
RITI: ONO ISP SPAIN 192.168.0.249
RACK AB first floor MAIN RACK, 192.168,0.133, 192.168.0.138
RACK CD zero floor RX RACK, 192.168,0.132
RACK GH second floor, CONTROL2B, 192.168.0.139
RACK EF First Floor PAPER RACK, SW MODEL: DLINK DES1026G
SW MODEL : DLINK 1016D
Connection cabling between racks
RITI to RACK AB
192.168.0.249 (FE01) 192.168.0.133 (G1)
g1
Normal
35m-36m
RACK AB – RACK AB
192.168.0.133 (G47T) 192.168.0.138 (23T)
g47
Normal
0m
RACK EF – RACK AB
SW DLINK DES1026G (25G) à 192.168.0.133 (03G)
G3
Normal
38m-42m
RACK EF – RACK EF
SW DLINK DES1026G (26G) à SW DLINK 1016D (16G)
0 m
RACK AB – RACKCD
192.168.0.138 – (24T) 192.168.0.132 (47)
g24
Normal
30m
RACK GH –RACK AB
192.168.0.139(01G) --192.168.0.133(48T)
g1
Normal
32m-34m
FW
5.4.2.13 //B5.3.0.2 5.4.2.13 // B5.3.0.2 5.4.2.13 //B5.1.1.1 5.4.2.13 // B5.1.1.1 there is no VPN,
