hosregla
Aug 25, 2015Aspirant
best option, 2 netgear Prosafe GS724T-400EUS in trunking or 1 gs748teu,
best option, 2 netgear Prosafe GS724T-400EUS in trunking or 1 gs748teu, do you have the same performance both options. 2 netgear prosafe 24 are best price. 2 Netgear ProSafe GS724T-400EUS - Sw...
- Aug 25, 2015
Hi hosregla,
Welcome to the community!
I would go with the single GS748T, it's much easier to manage if you only have one unit. In terms of performance, this should be the same, using 2 switches with trunk ports benefits works better if you have multi-sessions on both switches. If your network activity uses single session, it will max out the first port's bandwidth before using the second one. I am hoping some other users here can give more input.
If you have more questions, feel free to ask.
Thanks,
hosregla
Aug 26, 2015Aspirant
GS724Tv3,GS724Tv3,GS748Tv4H1,GS748Tv4H2
have 5 units, should create trunking between them. each unit is separated by 40-60 m
is it necessary create vlan to make trunking???
thks.
Alfonso Silván.
JohnRo
Aug 26, 2015NETGEAR Employee Retired
Hi hosregla,
I have to be clear on what you are trying to accomplish, do you just want the devices to be connected on a single network? If you have a diagram of your network plan, that will help us in giving you the correct suggestions.
I'll look forward to your response.
Thanks,
