hosregla
Aug 25, 2015Aspirant
best option, 2 netgear Prosafe GS724T-400EUS in trunking or 1 gs748teu,
best option, 2 netgear Prosafe GS724T-400EUS in trunking or 1 gs748teu, do you have the same performance both options. 2 netgear prosafe 24 are best price. 2 Netgear ProSafe GS724T-400EUS - Sw...
- Aug 26, 2015
Hi hosregla,
Welcome to the community!
I would go with the single GS748T, it's much easier to manage if you only have one unit. In terms of performance, this should be the same, using 2 switches with trunk ports benefits works better if you have multi-sessions on both switches. If your network activity uses single session, it will max out the first port's bandwidth before using the second one. I am hoping some other users here can give more input.
If you have more questions, feel free to ask.
Thanks,
hosregla
Sep 12, 2015Aspirant
Hi.
i would like configurate MAC FILTERED by each port.
Where can i configarte it?
thks.
JohnRo
Sep 14, 2015NETGEAR Employee Retired
Hello Hosregla,
You can confugure MAC Filtering on Security>Traffic Control then MAC Filter>MAC Filter Configuration.
You may check the details on the software administration manual see page 200. (GS724T)
For GS748T please click here, see page 195.
Thanks,
- hosreglaSep 15, 2015Aspirant
Hello friend:
My portatil have that mac:
i have just put this configuration, in my switch, but I LOVE you get the opposite effect.
my portatil don´t run ;)
Thks.
- JohnRoSep 16, 2015NETGEAR Employee Retired
Hello Hosregla,
Yes, the MAC address entered will be the one filtered. What are you trying to filter by the way? Do you want the Portatil to be the only one with access?
Thanks,
- hosreglaSep 16, 2015Aspirant
yes. a lot of thanks by your time.
I like that each switch port was exclusive to a single Mac. - JohnRoSep 17, 2015NETGEAR Employee Retired
Hello Hosregla,
No problem! Glad you got it working as you wanted.
Thanks,
- hosreglaSep 17, 2015Aspirant
I have not managed to set it as I wish . Can you help me? - JohnRoSep 18, 2015NETGEAR Employee Retired
Hello Hosregla,
What are you trying to accomplish? If you have a diagram, you can upload it here so that other members of the community can give thier suggestions.
Looking forward to your response.
Thanks,
- hosreglaSep 18, 2015Aspirant
ok. I will create a new post
"ideas for my LAN LOCAL with products NETGEAR"
thks.
