Ciscoisthebest
Jul 24, 2023Follower
Best version of software
Hello,
I need to update the switches and I don't know which version is the most recomended right now?
Model Name Boot Version Software Version
GS728TPPv2 1.0.0.5 6.0.4.6
GS728TP 2.0.0.11 6.0.1.18
I don't belive that the leatest version is the best right now
Head to https://www.netgear.com/support/ and enter the correct model according to your product model label ... and you will get offered the appropriate downloads.
https://www.netgear.com/support/product/gs728tppv2#download
https://www.netgear.com/support/product/gs728tp#download
1 Reply
