Lapsapper
Jul 19, 2023Aspirant
Broken GC110 switch after unplugging and replugging the switch
Hello, I have a major issue with my network switch not booting up correctly and working normally, the power led of the switch shows an amber color continuously. All network ports are not working as ...
michaelkenward
Jul 19, 2023Guru - Experienced User
Lapsapper wrote:
Does anyone know what to do?
Anyone who does know about those things probably hangs out in the section where they talk about them.
The GC110 is a switch.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Discuss Ethernet Switches Plus and Pro Managed
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Lapsapper
Hi!
Woops, unfortunately I've created this topic in the wrong category. As I've mentioned above, I've tried resetting the network switch and I've looked through the troubleshooting page of the GC110 switch.
No appliance can communicate to the switch, so I cannot factory reset the switch using the network interface / app. Thus I tried doing it using the reset button but this was not successful as well. So there aren't many alternative troubleshooting steps out there for me that I can try.
