DonD
Feb 06, 2016Guide
Can GS108E, WN203, and FVS318N support a VLAN 0?
I configured a Netgear FVS318N router, Netgear WN203 access point, and Netgear GS108E switch, all VLAN aware, to support two VLANS, VLAN 1 and VLAN 2. When I got to church to install the equipment a...
- Feb 07, 2016
Hi DonD,
Have you tried to change the IP settings on your FVS318N to use subnet zero? If yes, is there an error message that appears?
DaneA
NETGEAR Community Team
DonD
Feb 08, 2016Guide
Hi DaneA,
Following on your suggestion, I changed the IP address of the router for the Default VLAN to subnet "0" and found it worked. Now, any use of VLAN 1 results in a subnet of "0". So, I'll setup "FUMC_Staff" to run on subnet "0" (VLAN ID 1), and "FUMC_Guest" to run on subnet "1" (VLAN ID 2). Guess my problem was I was thinking "VLAN ID" corresponded directly to the subnet. Thanks again for your help, DaneA!
Don
DaneA
Feb 08, 2016NETGEAR Employee Retired
Hi DonD,
You're welcome again! :) I am happy to know that its working. :)
Don't hesitate to post your future concerns here in the community.
Cheers,
DaneA
