Retired_Member's avatar
Retired_Member
Jul 26, 2020
Can the GS305E switch be used as a DHCP server?
I found in the documentation it says that the switch can be used as a DHCP relay but I couldn't find anywhere if it can be used as a DHCP server. I want to connect it straight to the internet without...
  • DaneA's avatar
    Jul 26, 2020
    Retired_Member,
    Welcome to the community! :)
    The GS305E does not have a DHCP server function.  If you need a switch that has a DHCP Server function, I suggest you any of the M4300 switch models.
    To know more about the M4300 switch models and their specifications, kindly check the data sheet here
    DaneA
    NETGEAR Community Team
ProSupport for Business
