nicke20's avatar
nicke20
can this managed switch be used in open mode
I have been offered a GS724TP-200EUS sealed in box from a local company that have three to sell at less than half price, it would greatly clean up my home setup that uses lots of poe injectors and tw...
  • schumaku's avatar
    Jul 03, 2020
    All Smart Managed Plus and Smart Managed Pro switches run out of the box like a non-managed switch, all ports are member of the default VLAN 1 all untagged.
    There is no management software required anyway, these are all locally Web managed units.
    To avoid some good friends or neighbours visiting you I suggest you take management control at least to the level of changing the default admin password, and change the default SNMP config for read and read+write. Oh and while you are on it ensure you run a current firmware, see https://netgear.com/support
ProSupport for Business
