kiral9
Sep 14, 2023Follower
Cannot access Netgear XS708E switch
In my router I can see that the switch gets an IP address, but I cannot access the webUI from its IP address. I tried resetting it (holding the Factory Reset button for more than 10 secs) but this d...
schumaku
Sep 14, 2023Guru - Experienced User
What IP address does the NETGEAR Switch Discovery Tool (NSDT) show for your XS708E, is it a v1 or v2? The default LAN IP address is 192.168.0.239/24, or does it get a DHCP address assigned from your DHCP server'.
schumaku
Sep 15, 2023Guru - Experienced User
For the early XS708Ev1 (XS708E-100xxx) there might be no Web UI. Instead, you have to use the ProSAFE Plus Utility - available for Windows only.
Due to some uncontrolled phase-out process, the Release Notes are no longer available along with the download link, at least on the English KB.
For the XS708Ev2 (XS708E-200xxx), a local device Web UI is available. Consult the fine 8-Port or 16-Port 10-Gigabit/Multi-Gigabit Smart Managed Plus Switch with 1 Copper/SFP+ Combo Port Models XS708Ev2 and XS716E User Manual "Access a switch connected to a network" starting from p.17, resp. "Access a switch that is off-network" starting from p.18. Either way, regardless of the computer OS, the NETGEAR Switch Discovery Tool (NSDT) is available for MacOS, Windows, and popular Linux distributions.
