rstahl02
Nov 03, 2015Aspirant
Can't access GS108E switch on Windows 10
After upgrading to windows 10 I can't access my GS108E switch. Get "A fault occurred contacting the server. Fault message is:HTTP request error". Any idea what is the problem?
- Jan 13, 2016
I reset the switch to factory defaults & it now works in WIN10. Wish I could label each port so I know whats connected to it. It's a bummer not knowing what I connected to all 8 ports. I should be allowed to label each port with a name. Can that be done? Thanks for your help. Close the case.
Ron
rstahl02
Nov 28, 2015Aspirant
Cache cleared. The IP is static (Which it has been sence day 1.). I just changed it to dynamac. Its the same router I have used from day 1 and I see the IP. Remember, EVERYTHING WORKS ON WINDOWS 7 BUT NOT WIN10.
I am going to check it as dynamac and see what happens, will let you know.
Ron
rstahl02
Dec 09, 2015Aspirant
Is anybody reading this stuff??? Changed to dynamic IP. NO help. Are other Windows 10 useres having the same issue? I am about ready to give up. I need an answer. I am useing the latest version of your program. I have done everything suggested and still can't assess my GS108E. Works fine on Windows 7.
- DaneADec 09, 2015NETGEAR Employee Retired
Hi rstahl02,
We currently have a GS108Ev1 (yours is a GS108Ev2). Our PC has been updated to Windows 10 recently. I was able to install the latest version of the ProSAFE Plus Configuration Utility and it discovered our GS108Ev1 as shown on the image below. Our GS108Ev1 has the latest firmware version.
Kindly try to uninstall then reinstall the latest version of the ProSAFE Plus Configuration Utility v2.3.5 on your Windows 10 PC. You may download it here.
DaneA
NETGEAR Community Team
- rstahl02Dec 10, 2015Aspirant
I already had the latest software but I removed & reinstalled it. No help. This is strange. Works on your WIN10 but not mine. I put WIN10 on 3 computers and it only worked OK on one. I removed it from 2. This Dell XPS15 is the only one that has WIN10. Strange. Is there another way to access this router? I tryed direct IP but NG. Maybe I needed to add something to the IP? What is the secreat way to access this router?
Ron
- DaneADec 10, 2015NETGEAR Employee Retired
Hi rstahl02,
Just to clarify, the GS108Ev2 is a switch not a router. You mentioned that you got it working on one Windows 10 PC of yours. With regard to that, do you have any software firewall or anti-virus enabled on your Dell XPS15 (or other Windows 10 PC)? If ever there is, kindly try to disable it then check if the GS108Ev2 will be detected by the ProSAFE Plus Configuration Utility.
DaneA
