rstahl02
Nov 02, 2015Aspirant
Can't access GS108E switch on Windows 10
After upgrading to windows 10 I can't access my GS108E switch. Get "A fault occurred contacting the server. Fault message is:HTTP request error". Any idea what is the problem?
- Jan 12, 2016
I reset the switch to factory defaults & it now works in WIN10. Wish I could label each port so I know whats connected to it. It's a bummer not knowing what I connected to all 8 ports. I should be allowed to label each port with a name. Can that be done? Thanks for your help. Close the case.
Ron
DaneA
Dec 13, 2015NETGEAR Employee Retired
Hi rstahl02,
I apologize for that. There are just 2 ways to configure the GS108Ev2: first is using the ProSAFE Plus Configuration Utility and second to access the web-GUI using a browser provided that the switch is on the latest firmware version. What is the current firmware version of your GS108Ev2?
DaneA
NETGEAR Community Team
rstahl02
Dec 14, 2015Aspirant
1.00.12 is the firmware version. I use my WIN7 computer to assess the switch.
Ron
