ashcam
Feb 01, 2019Aspirant
Can't access GS108Ev3
Hi, I've got a problem trying to access my GS108Ev3 when it's connected to my router. If I disconnect it from my router and just leave my computer connected then I can access it, however once I conne...
- Feb 02, 2019
Solved - by default the switch has DHCP enabled, I disconnected it from my router, manually configured my computer's network so that it was the same as the switch, then I could connect to it, dissable DHCP and add a static IP address to the switch, then apply changes, connect to router and it's all good.
ashcam
Feb 02, 2019Aspirant
- Apr 12, 2023Retired_Member
