GoBlazers
Sep 20, 2021Aspirant
Can't Change Default Password on MS510TX
I recently upgraded to the MS510TX switch. I have begun configuring the switch using the default password and the web browser interface. I updated to firmware version 6.7.0.51 (latest update) last ...
- Sep 23, 2021
Update: I have tried another password variation that did NOT contain special characters, and that one was accepted and saved to the device. The password has now been changed from the default password, but it seems there are restrictions on multiple special characters that the system will actually acceptable.
schumaku
Sep 21, 2021Guru - Experienced User
Scratch SCC - it was EoL a long time before the MS510TX/MS510TXPP were launched. No idea why Netgear does still list SCC in the downloads for all these switches.
Have a bunch of MS510TX out in the field, convinced we have changed the passwords several times with 6.7.0.50 and 6.7.0.51.
This leads to the question which "special" chars are used in the new password, or why these might slide-through the input parsing.
- GoBlazersSep 21, 2021Aspirant
I've tried several passwords that meet the requirements and utilize different special characters which should not be a problem. None of them work. I contacted the support team at NETGEAR and they are looking into the issue as well, but still have no clue why the password won't save.
- GoBlazersSep 23, 2021Aspirant
- schumakuSep 23, 2021Guru - Experienced User
For the still guessing reader - what special chars do you have in mind causing the issue?
