GoBlazers
Sep 20, 2021Aspirant
Can't Change Default Password on MS510TX
I recently upgraded to the MS510TX switch. I have begun configuring the switch using the default password and the web browser interface. I updated to firmware version 6.7.0.51 (latest update) last ...
- Sep 23, 2021
Update: I have tried another password variation that did NOT contain special characters, and that one was accepted and saved to the device. The password has now been changed from the default password, but it seems there are restrictions on multiple special characters that the system will actually acceptable.
GoBlazers
Sep 21, 2021Aspirant
I've tried several passwords that meet the requirements and utilize different special characters which should not be a problem. None of them work. I contacted the support team at NETGEAR and they are looking into the issue as well, but still have no clue why the password won't save.
GoBlazers
Sep 23, 2021Aspirant
