GoBlazers
Sep 20, 2021Aspirant
Can't Change Default Password on MS510TX
I recently upgraded to the MS510TX switch. I have begun configuring the switch using the default password and the web browser interface. I updated to firmware version 6.7.0.51 (latest update) last ...
- Sep 23, 2021
Update: I have tried another password variation that did NOT contain special characters, and that one was accepted and saved to the device. The password has now been changed from the default password, but it seems there are restrictions on multiple special characters that the system will actually acceptable.
tiward
Nov 29, 2025Aspirant
Hi,
just a 2025 update. i had the same issue, when i did a factory reset, you are meant to get the 'change password option' that only appears for me in Edge, it didn't appear in Chrome. so load the page up in Edge after a reset and you can then change the password with out the 'no such user : admin' error.
schumaku
Nov 30, 2025Guru - Experienced User
tiward This could be an oversight when the California required default password change was introduced.
Please be more specific on the current firmware version in place, also tell us a little bit more on the switch operational history.
- tiwardDec 01, 2025Aspirant
latest firmware as of this message (.72 i think) and does not get used very often (backup switch) this is mor of an FYI in case anyone else comes up with the error "The Password cannot be updated. No such user admin."
