Phihtr
Jun 20, 2016Aspirant
Can't connect the Roku to my Netgear GS108ev3 switch
Hi there, I just bought a Netgear GS108Ev3 switch, and have a problem connecting my Roku player to the switch. I connect my switch to my cable modem, and connect my Roku to one of the ports on the s...
- Jun 24, 2016
Hi Phihtr,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
Phihtr
Thanks JohnRo.
So that I have to connect my Roku to the router, and the router connect to the switch, the switch connect to the modem? or I have to connect the router to the switch, and connect the switch to the router, and the router connect to the modem? I have Netgear GS108ev3 8-port switch, so how many computer can I connect to the switch?
Thank again for your help.
JohnRo
Jun 20, 2016NETGEAR Employee Retired
Hi Phihtr,
The connection will be Modem>Router>Switch and then the computers. The Modem will supply the internet, the router will translate the internet IP from Public to Private and the serve as the DHCP server. The router will give the devices an IP address for each device plugged into it and the switch. You'll have a total of 7 ports available on the switch for the computers/devices.
Thanks,
- Apr 12, 2023Retired_Member
