tiwing
Feb 02, 2021Aspirant
can't get a single vlan connection to get an IP from pfsense
Hi all, totally new to VLAN, but a week ago when I ordered the switch it felt like a better idea than it does now. Regardless of how much I "THOUGHT" I understood what needed to be done, it's clear...
schumaku
Feb 03, 2021Guru - Experienced User
Looks ok from what you have posted here on the switch side. Ensure there is a dedicated network (IP subnet) with a DHCP server, with routing or NAT-routing to the Internet configured.
tiwing
Feb 03, 2021Aspirant
appreicate the reply. I've been up all night trying to make it work... it's now in a box with a return label on it. I don't _need_ it at my house as I have two physical networks that work just fine.. and i'm just not smart enough to figure it out... so back it goes. cheers.
- schumakuFeb 03, 2021Guru - Experienced UserI don't think returning is required. The problem isn't the switch - much more the pfSense device config.
Start here FMI https://docs.netgate.com/pfsense/en/latest/vlan/index.html
Networking is not something one can quickly learn in a night...- tiwingFeb 03, 2021Aspirant
Hi, agree 100% that the problem isn't likely the switch, but it's the thing I _can_ return and I don't have the time or patience to learn the details of pfsense to the nth level. What this adventure reminded me is that making something too complex for what is needed is a mistake. I already have high availability in my pf boxes with working failover (who needs that at home??), and two separate (physical) networks to separate home and guest traffic. Maybe in a year I'll get the itch again to mess around with it. I appreciate your willingness to help!
