mjolnier70
Dec 03, 2024Aspirant
Can't get to GSS116E Switch after backhauling Google Nest Wifi Pro Setup
I recently connected my Google Nest WiFi Plus setup via a backhaul wiring and everything seems to be working correctly. However, I no longer have access to the GSS116E switch admin panel. It show...
- Dec 03, 2024
Nevermind, figured out that if you unplug the switch for a minute and plug it back in it gets a new IP address from the new network. Did another scan and found it and was able to get back in. Thanks!
mjolnier70
